Where is the thermostat (flame sensor) located at on this microwave?
What part did you call "flame sensor"?
thermostat. Problem is mw won't do anything after potato caught fire inside.
Normally the thermal fuse for the cabinet blows when a fire occurs.
The cabinet needs to be removed to access this part under most circumstances.
Remove the outer cabinet and look for a 2 wire component normally on the left side near the top of the microwave. Check it for continuity.
Matt
