hilliby
#1 Posted : Wednesday, March 12, 2008 2:42:58 PM(UTC)
hilliby
my oven quit heating replaced both broil and bake eleament and still have no heat
#2 Posted : Thursday, March 13, 2008 12:00:12 PM(UTC)
Pull it off, remove the rear cover and check the high limit switch (#23 on the body break down diagram) for continuity.
Replace the high limit switch if it's open.
- The part number for the high limit switch is AP3749994
Here are the break down diagrams for the Jenn Air range Model SVD48600W
