haljr5
#1 Posted : Thursday, December 10, 2009 4:08:30 PM(UTC)
haljr5
Dishwasher will not drain. It appears that the timer is not engaging the solenoid that allows the cycle to drain.
Timer dial turns through cycle to the stop position. Machine seems to stay in the "wash" cycle throughout the time it runs.
Should I try timer or the solenoid.
Thanks -
#2 Posted : Saturday, December 12, 2009 2:56:31 AM(UTC)
Pump assembly replacement parts for MAGIC CHEF DU75CA-01 Dishwasher - Undercounter | AppliancePartsPros.com
I would get a meter and measure across the solenoid when it should be powered. If you see 120 volts then either the solenoid is toast or you have a mechanical problem with the solenoid or the flapper valve.
If no power then it is either the timer or a wire from the timer to the solenoid is broken/open.
You can then check the voltage and continuity of parts.
mtrivich
#3 Posted : Saturday, June 4, 2011 12:47:09 PM(UTC)
mtrivich
I did the troubleshooting below, still no drain.
Then I disconnected the drain hose from the vacuum breaker on the sink top connecting to the garbage disposal, aimed the hose into a bucket, cycled the timer and the tub drained into the bucket.
I pulled the chrome cap off the breaker, unscrewed the top and found a wad of gunk blocking the flow.
I removed the gunk, reassembled all and the (18 year old) washer works like new. While I was at it I cleaned the tub float and door mounted spot remover. Wow! I'm ready for a few more years.:)
Mike
Originally Posted by: denman Go to Quoted Post
