Lately my Maytag LDG9306AAE gas dryer started taking a long time to dry clothes. Like 2 hrs. or more. I checked the vents and it was pretty filthy even though we clean the trap after every load. So I vacuumed out everything I can get out without taking the vent assy. apart. It seems to have good air flow. I watched the burner with the front off and it starts and only runs about 30-45 seconds then shuts down. I tested the high limit thermostat and thought it was defective because I can bypass it and the burner will run for at least 2 minutes (that's as long as I let it run, might have gone longer) So I ordered a new high limit switch and installed it and the problem is the same. It will only run as long as the high limit switch is bypassed. I also noticed the timer advances normally in the regular and air fluff cycle but it won't advance on the auto dry cycle. Anybody got any ideas?
Thanks, Scott
Originally Posted by: Cudaman  Lately my Maytag LDG9306AAE gas dryer started taking a long time to dry clothes. Like 2 hrs. or more. I checked the vents and it was pretty filthy even though we clean the trap after every load. So I vacuumed out everything I can get out without taking the vent assy. apart. It seems to have good air flow. I watched the burner with the front off and it starts and only runs about 30-45 seconds then shuts down. I tested the high limit thermostat and thought it was defective because I can bypass it and the burner will run for at least 2 minutes (that's as long as I let it run, might have gone longer) So I ordered a new high limit switch and installed it and the problem is the same. It will only run as long as the high limit switch is bypassed. I also noticed the timer advances normally in the regular and air fluff cycle but it won't advance on the auto dry cycle. Anybody got any ideas?
Thanks, Scott Did you ever figure out what the problem was?
