Ono Nadagin
#1 Posted : Thursday, December 10, 2009 11:14:10 AM(UTC)
Ono Nadagin
Microwave will not demonstrate it is connected to power at all... wont do a thing... the outlet it is plugged into is good on both receptacles as they were tested with a voltage tester and then a stick blender just to make sure :)
I was unable to find a manual for it on this great site as I have for other appliance repair issues I have fixed with help from here
Is there an internal fuse that might have gone bad... it is a wall mounted unit as soon as I get a helper I will pull it down off the wall and hopefully by then I will have gotten some info from you guys here
the manuals troubleshooting says for no power at all check for a blown circuit fuse or a main breaker(my breaker is good and the outlet is powered)
And it says to make sure the controls are set correctly... what controls could they mean by this comment when it is under the heading of microwave wont power on at all?
TY
Key
Ono Nadagin
#2 Posted : Tuesday, December 15, 2009 10:42:26 AM(UTC)
Ono Nadagin
could anyone point me to a schematic for this LG model
ApplianceHelper
#3 Posted : Thursday, March 3, 2011 12:59:07 PM(UTC)
ApplianceHelper
I don't have the schematic for this exact microwave but chances are a fuse has gone bad. Go to the video link below and see if it helps to test the fuse to see if it needs to be replaced.
Microwave No Power Repair : ApplianceRepairLesson.com
Good Luck!
