mel113
#1 Posted : Thursday, December 10, 2009 10:54:59 AM(UTC)
mel113
Hello, I am having difficulties with the idler pulley and dryer belt. I just replaced the motor in the dryer, and now that I am putting the dryer back together, I am having problems with the dryer belt. It is rubbing up against the metal part of the idler pulley and the belt is too loose. I have looked at the diagram posted on this site, and it seems that the idler pulley arm should be pulled out more (please see a picture of my dryer issue at the photo link included at the bottom). I don't see another spring to pull it back more. What am I missing here?
Picasa Web Albums - serenitey - Dryer
Thank you for your help and Happy Holidays!
#2 Posted : Thursday, December 10, 2009 6:01:17 PM(UTC)
Try this
Remove the belt from the idler and motor.
Pull the idler to the far left.
Loop the belt onto the motor pulley
Release the idler pulley so that it puts pressure on the left hand side of the belt.
Should look like GE - Standard Capacity Models 1970-1990 in the diagrams.
mel113
#3 Posted : Friday, December 11, 2009 12:14:08 PM(UTC)
mel113
When I pull the idler pulley back to the left, the spring is going to bring it right back to where it is right now. Somehow, I need pull the arm back to the left to create the 45 degree angle that is shown in the diagram that is posted on this site. Am I missing a part? Another spring to pull the idler down towards the floor? I have included a couple more pictures.
#4 Posted : Friday, December 11, 2009 12:30:09 PM(UTC)
Sorry I do not understand if you pull it to the left then when released it cannot go to its present position as it is up against the belt coming down from the left hand side of the drum.
Where it is in your first picture is where it is supposed to be.
The difference is that the back side of the belt coming down from the drum the left hand side of the drum rides on the right side of the idler wheel.
You have it riding on the belt coming down from the right hand side of the drum.
This side should not touch the idler it should go from the motor pulley directly up and over the drum.
mel113
#5 Posted : Saturday, December 12, 2009 5:53:00 PM(UTC)
mel113
Oh thank you Denman! I figured out what you meant. I really appreciate your help! Happy Holidays!
#6 Posted : Sunday, December 13, 2009 1:08:16 AM(UTC)
Glad you got it up and running.
Sometimes I can see the procedure in my head but seem to have problems putting it down on paper where it makes sense to someone else.
Thanks for getting back to me.
May you and yours have a nice holiday season.
