t7433
#1 Posted : Wednesday, March 12, 2008 11:41:49 AM(UTC)
t7433
The washer will not stop filling up. I noticed on this blog that this may be a problem with the pressure hose switch that may of come off. Mine after filling up and turning timer to get it to stop filling up and spin out I noticed a steady stream of water leaking from the left front of the bottom outer tub. Could that be caused by the pressure hose switch?
#2 Posted : Thursday, March 13, 2008 10:16:46 AM(UTC)
Remove the bottom panel and check the pressure bulb and the pressure hose (#13 & #15 on the outer tub break down diagram).
Post your findings.
Here are the break down diagrams for the Amana washer Model ALW880QAC
