debbiegal
#1 Posted : Tuesday, December 8, 2009 3:20:49 PM(UTC)
debbiegal
we have to replace the dryer belt but the pulley came out and we can not see behind the motor to see where the spring attaches. it is connected to the pulley arm on one end. need your help. thenks debbie
sidfink43
#2 Posted : Friday, December 11, 2009 5:35:35 AM(UTC)
sidfink43
Hi Debbie
Look at the stickey at the top of this page and you will see pulley diagrams. See if one of them shows you how to do it.
Remember, the spring should be attached so that it causes the pulley wheel to put tension on the belt.
Good luck.
