brokenshoe
#1 Posted : Tuesday, March 11, 2008 9:28:41 AM(UTC)
brokenshoe
fixed motor coupler......now washer won't stop filling and won't agitate :eek:
Matt S
#2 Posted : Tuesday, March 11, 2008 2:06:07 PM(UTC)
Matt S
Sounds like the pressure switch hose came off.
That is a clear rubber hose running from the bottom right side of the tub up to the level switch.
Check that hose. You should be good. ;)
Matt
t7433
#3 Posted : Wednesday, March 12, 2008 11:13:21 AM(UTC)
t7433
I have the same problem. If the hose came off would the tub leak? Mine after filling up leaks from the left front of the bottom outer tub. Or would it be the tub seal?
brokenshoe
#4 Posted : Wednesday, March 12, 2008 1:51:35 PM(UTC)
brokenshoe
Thank you all!!! The problems were all solved, and we're back to doing laundry again. Amazing experience having others help us without costing a dime. brokenshoe family
Matt S
#5 Posted : Wednesday, March 12, 2008 2:02:46 PM(UTC)
Matt S
Sounds like your tub seal.
Matt
