greener
#1 Posted : Tuesday, March 11, 2008 9:02:29 AM(UTC)
greener
Probably like others, the plastic pins on the inside which hold the produce drawers broke off. So I ordered and received the new pins. My question is in installation.
It seems to be that these should be epoxied and then some type of clamp should be extended across the inside so the epoxy drys firmly with the pins.
If this is the case, do I need to remove all food? is their a better adhesive, which is not so toxic than epoxy? am I doing this wrong?
thanks for any advice.
