CSAYERS
#1 Posted : Tuesday, December 8, 2009 6:33:07 AM(UTC)
CSAYERS
My Washer Works Fine Accept The Agitator Will Not Move In The Wash Cycle Could It Be A Belt And How Do I Access The Unit To Find Out Or See All The Parts Inside
applianceman
#2 Posted : Tuesday, December 8, 2009 2:26:42 PM(UTC)
applianceman
If it will spin but won’t agitate the first thing I would look at is the agitator coupling. Attempt to turn the agitator by hand. It shouldn’t turn easily and if it does the agitator coupling is stripped out. To replace it remove the agitator by lifting straight up. Once off you will see the coupling (it may be called an air bell on parts breakdown). A 7/16 bolt holds it on. If that doesn’t seem to be the problem post back and we will go from there. Clothes Washer Repair Guide
Removing Maytag agitator (Washer Repair)
by Guest 3/30/2024 5:55:35 PM(UTC)
Maytag topload agitator (Washer Repair)
Belarus Guest 1/30/2024 7:23:54 AM(UTC)
GE top load with agitator - drum is free spinning (Washer Repair)
by JLS79 12/18/2023 8:21:30 AM(UTC)
Maytag Bravos Washer - Agitator spins fast/Drums spins slow (Washer Repair)
by JDugdale 8/29/2023 9:04:08 PM(UTC)
oil leaking under agitator into the washing drum (Washer Repair)
by sarte 8/1/2023 8:16:28 AM(UTC)
Beware when buying Agitator WPW1011020 (Washer Repair)
by Guest 7/18/2023 3:49:04 PM(UTC)
Should basket spin with lower agitator? (Washer Repair)
by bdollar 6/2/2023 4:44:56 PM(UTC)
Frigidaire Gallery Model GLWS1349AS0 Agitator Will Not Come Out (Washer Repair)
by Techowl 1/23/2023 10:39:56 AM(UTC)
My agitator bolt will not come out (Washer Repair)
by Guest 8/14/2022 4:47:19 PM(UTC)
GE Hydro Wave Quiet Agitator Wash System Lint Screen? (Washer Repair)
by Alphonse 3/13/2022 1:50:28 PM(UTC)
Whirlpool agitator&spin issues (Washer Repair)
by Guest 1/16/2022 10:55:31 AM(UTC)
Agitator barely moves (Washer Repair)
by Xicano69 10/25/2021 7:16:40 PM(UTC)
Grinding with working agitator. (Washer Repair)
by Guest 9/23/2021 1:10:18 PM(UTC)
Whirlpool washer agitator working but with grinding noise (Washer Repair)
by Guest 9/23/2021 1:06:39 PM(UTC)
Agitator Stuck! Can't get it out. (Washer Repair)
by TWash2 6/16/2021 3:22:28 PM(UTC)
