Hello, I just moved and hooked my washer up with new flood proof hoses I just bought from HomeDepot. I also just replaced the door lock. I got through 1 wash with the old hose, but when I tried washing with the new ones I get an error code of F H. Please Help. I really need to wash.
Thank You!
Hi Fishgirl (yeah that sounds odd) The error message you are getting is likely because the hoses are slowing down the fill rate for your machine, and it is essentially being timed out. It may be that you just cannot use those hoses with your machine. Here is a service manual for your model which will discuss the error message in more detail. https://secured.whirlpoo...6bc2ce/$FILE/8178604.pdf
