Stove stopped working, but burners were still operational. We replaced the valve and regulator assembly but still are having problems. Below are steps taken to fix so far.
1. Igniters working, but no gas available to bake oven. 2. Tested with meter and we found that power is available to valve and regulator assembly. 3. Replaced valve and regulator assembly assuming that it was non-operational 4. Broiler ignites and gives gas, but the bake burner is still not giving any gas. The ignitor will glow, but there is no sign of gas or available flame.
Thanks very much for any assistance.
Oven now is working. The problem was the ignitor. It was glowing and so I thought it was working fine, but it was not heating up to a high enough temperature, and so a built in safety switch turned off the flow of gas.
My faulty ignitor was glowing red, which was not hot enough to allow gas flow. The replacement ignitor glows white, and now the gas lights up without any problem.
Apologies for my unnecessary post.
