mgreenly
#1 Posted : Saturday, March 8, 2008 12:58:52 PM(UTC)
mgreenly
I listed model number that is stamped on the tag just inside the lid but have had no hits when searching for my model number (like it doesn't exist). All white, top loading, 1 black knob on the left of the console (white,colors,bright colors, etc), covered bleach port (not used), and coin-op.The top of the case (lid and console) tilt up, i would guess for maintanence.
Was a hand me down from a laundry, marked that its from 1980.
It leaked on the floor when filling up so I figured out how to open the case. The leak seems to be coming from the inlet hose.It's leaking in between the 1st and 2nd part of the hose at a 1.5" plastic cylindracal piece with slots in it (What is this?). Also, the 2nd part that connects into the tub looks corroded so I should probably replace that.I'm not sure how to get that hose unhooked from the tub. There seems to be a small black plastic ring holding the hose in place from the inside of the tub.
And any ideas on whats up with my model number?
Sorry for the long post and thanks in advance!
Edit: OK apparently through browsing my washer looks identical to either an A21CA, A21CM, or A21CT. From looking at the diagrams these are the part numbers I need (but what are they?):
2-6154, 2-15120
2-13013
2-13057
Model A21CM
#2 Posted : Sunday, March 9, 2008 1:38:56 PM(UTC)
Originally Posted by: mgreenly Go to Quoted Post
...It leaked on the floor when filling up so I figured out how to open the case. The leak seems to be coming from the inlet hose.It's leaking in between the 1st and 2nd part of the hose at a 1.5" plastic cylindracal piece with slots in it (What is this?). Also, the 2nd part that connects into the tub looks corroded so I should probably replace that.I'm not sure how to get that hose unhooked from the tub. There seems to be a small black plastic ring holding the hose in place from the inside of the tub....
The part where the leak is coming from are "water injection system". It consists of three parts which should be replaced.
They are:
The nozzle. The part number is AP248052
The injector valve. The part number is AP249453
The sleeve. The part number is AP253030
Or you can buy all of them as a kit (included the hoses and new hose clamps).
The part number for the water injector hose kit is AP245425
The "small black plastic ring holding the hose in place" can be cut off and replaced with a regular hose clamp.
mgreenly
#3 Posted : Sunday, March 9, 2008 5:45:35 PM(UTC)
mgreenly
Thanks so much, Gene.
Just out of curiousity...
Why is my washer marked as A21CS instead of -A,-M,or -T. Or maybe this is common?
Also, what is the purpose of the plastic sleeve between the hoses?
