The dishwasher was leaking water slightly thru the door handle last night. Then this morning, we could start the cycle, which would run for about 30 seconds, and then the lights turn off and the dishwasher stops.
Can you restart the dishwasher after it stopped? Check if the middle spray arm manifold and its hanger (#6 & #7 on the diagram) are in place and properly connected to the water feed tube when the upper dish rack is in. Gene.
Thanks Gene, All of the sprayer arms seem to be attached correctly, and the water is hooked up. The dishwasher does not start if you try a second time. It just does the same thing. Lights come on for 30 secs, then everything stops.
Remove the inner door panel and check all wires and connections. Check the door switches.
