charles14
#1 Posted : Thursday, December 3, 2009 6:07:18 PM(UTC)
charles14
when connect water line to washer leak around value when both is connected but not when just one line is connect
#2 Posted : Friday, December 4, 2009 1:14:32 AM(UTC)
Replacement parts for taa500 models | AppliancePartsPros.com
Without actually being there and seeing the leak location cannot be of much help.
I would remove the valve and check it.
Your problem does seem very strange.
I would replace the valve unless you can find the problem.
