The interior glass of my self cleaning built-in Whirlpooll oven door cracked due to operator error...mine.
I have the replacement glass and have removed 6 visible, easy to remove screws on edge of door....there are two more screws on the bottom part of the door which I can't access with any tools I have....how am I do get the door apart so I can install the new glass.
Should I attempt this? IS it more difficult than I bargained for. Help.
tin chef
In order to replace the glass you need to take the whole door off. It is pretty difficult procedure . My advise would be to get technician to do it.
