Once belt is over drum and pully is the belt suppose to fit secure (tight) or loose
Once belt is over drum and pully is the belt suppose to fit secure (tight) or loose Tight See the STICKY at the top of this forum if it is loose. |
THIS FORUM IS DEAD!!!!!!! |
