Same kenmore dryer, different problem. She won't heat up now. Runs but no heat. Maybe I should keep this dryer on a dolly for a few months? They say stuff like this runs in 3's. Any help appreciated
Groups: Expert
make sure you have 220 volts ... if you only have 110 the dryer will run but not heat... or else you knocked a wire off getting the screwdriver out of the lint filter.... check it out.
hope i am checking the outlet correctly. Its a 4 prong it has a (L) at the top 2 (l )one either side and a (O) at the bottom. I checked one side and the bottom, and the other side and the bottom. only have 120 on right side.......nothing on left. 30 amp Breaker didnt trip off. Reset it anyway........still same reading
