DAVE2707
#1 Posted : Monday, November 30, 2009 2:26:11 PM(UTC)
DAVE2707
I have a Comfortmaker furnace that continues to run. I have the house set at 70 degrees. The thermostat says 70 and the furnace will start up and run for about 5-8 minutes. It will shut off and sit for about 5 minutes then it will start back up and run again. The house is insulated well, and the house is warm but the furnace keeps running. any suggestions on a few things to check before calling in a tech?
tony_pullen23@yahoo.com
#2 Posted : Tuesday, December 8, 2009 4:30:41 PM(UTC)
got to be a thermostat problem, I would think. b e careful if you replace i yourself. watch your wiring closely, and read your instructions
bob1313
#3 Posted : Friday, December 11, 2009 9:35:09 AM(UTC)
bob1313
I second the thermostat problem. Before you replace it try to just recalibrate it. or just replace it!
