Tonygriz
#1 Posted : Wednesday, March 5, 2008 5:01:19 PM(UTC)
Tonygriz
My over had an element burn up. So I ordered a new heating element and installed it. Now the oven will not heat over 270 degrees. what can I check to see why the oven is not heating up to the selected temp.
roycreamer
#2 Posted : Friday, March 7, 2008 4:14:42 PM(UTC)
roycreamer
Groups: Expert
Views messages in topic : 79
your circuit breaker, make sure you're getting 220 volts.
Jennair oven panel not working - can I use it anyway? (Oven Repair (including Ranges and Cooktops))
by pos oven owner 9/22/2014 6:29:04 PM(UTC)
JennAir Oven Self Cleaning Troubleshooting (Oven Repair (including Ranges and Cooktops))
by lylecm 4/3/2014 2:22:13 PM(UTC)
Jennair oven control panel partial function failure (Oven Repair (including Ranges and Cooktops))
by Jcowin 5/20/2013 8:09:17 AM(UTC)
Jennair Oven Problems! (Oven Repair (including Ranges and Cooktops))
by dazras 3/18/2013 7:03:17 PM(UTC)
Jennair Oven not holding temperature (Oven Repair (including Ranges and Cooktops))
by karenrjwhite 12/21/2012 5:30:35 PM(UTC)
JennAir oven will not bake (Oven Repair (including Ranges and Cooktops))
by lamard 11/19/2012 4:35:23 PM(UTC)
Jennair oven (Oven Repair (including Ranges and Cooktops))
by Michaelminor 9/10/2012 5:14:22 PM(UTC)
Power Loss Message on JennAir Oven (Oven Repair (including Ranges and Cooktops))
by pellcity1014 1/8/2012 4:01:38 AM(UTC)
JennAir oven does not reach desired temperature (Oven Repair (including Ranges and Cooktops))
by acooney 12/22/2011 4:58:05 PM(UTC)
Jennair oven doors (Oven Repair (including Ranges and Cooktops))
by Ron6519 5/26/2011 1:06:05 PM(UTC)
Jennair Oven slow heating issue (Oven Repair (including Ranges and Cooktops))
by Dixcomputer 3/10/2011 2:21:14 PM(UTC)
Jennair Oven Not Working (Oven Repair (including Ranges and Cooktops))
by sncmeyer 11/16/2010 3:43:10 PM(UTC)
Jennair Oven cook top (Oven Repair (including Ranges and Cooktops))
by Filomena 9/30/2010 12:37:22 PM(UTC)
JennAir Oven woes (Oven Repair (including Ranges and Cooktops))
by SteveDB 9/20/2009 1:13:42 PM(UTC)
Replace Jennair Oven clock assembly (Oven Repair (including Ranges and Cooktops))
by glenn ross 8/30/2008 9:08:35 AM(UTC)
