Here are the parts, I used the "F" as it is probably the closest to yours
Replacement parts for NNS208BA models | AppliancePartsPros.com First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
Manually force a defrost cycle by turning the defrost timer cam (Item 20 in Section 5) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 36 in Section 5) from the wiring and measure it for continuity, usually around 20 ohms or so.
This unit uses glass type heaters which are not very reliable. Often you can see where it is burned out.
If the heater is OK
Remove one wire to the defrost thermostat (Item 29 in Section 5) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
