Just replaced heating element and Themostat (221f), but timer will not stop turning after a timed cycle..it does stop after the auto dry cycle. Model # is 110.62622100
Did the timer give you that same issue before the other parts were replaced?
Originally Posted by: Qtip Did the timer give you that same issue before the other parts were replaced? I don't think so. I removed the timer and filed the burnt contacts inside, but I still have the same problem. I can't believe they charge $100 for this timer.
