pappadon
#1 Posted : Friday, November 27, 2009 3:18:08 PM(UTC)
pappadon
I have an old wall oven that heats up but the temperature is way off. To get 350 degrees you have to set it to about 475 degrees. Should I replace the temperature sensor probe or buy a new wall oven. The temp. sensor goes for about $70 and I don't want to waste the money if there is more involved.
Thanks,
pappadon
#2 Posted : Saturday, November 28, 2009 6:03:16 AM(UTC)
Check that both elements are OK.
Many ovens use both elements to get the unit up to temperature during preheat.
Here is a good suite with troubleshooting help
http://www.applianceaid.com/elecrange.html
Check out 7, 8 and 21
pappadon
#3 Posted : Saturday, November 28, 2009 8:41:19 AM(UTC)
pappadon
Both elements are working fine. I haven't yet checked the resistance reading of the temperature probe, but thats my next task.
Thanks for your reply,
Pappadon
Kenmore wall oven repair (Oven Repair (including Ranges and Cooktops))
by pappadon 11/27/2009 3:07:38 PM(UTC)
