ryana
#1 Posted : Friday, November 27, 2009 3:16:32 PM(UTC)
ryana
Power to washer indicated by cycle options illuminating when selected however washer doens't run. Water doesn't flow and after about 10 seconds, the illuminated cycle selected deluminates.
#2 Posted : Saturday, November 28, 2009 2:27:16 AM(UTC)
Replacement parts for FRIGIDAIRE FDB1050REC0 Frigidaire/dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/p...df/Kinston/154547901.pdf
Try the service test to see if anything will run.
Check that the water valve is getting power (120 volts) when it should.
If yes and there is no water flow the valve's inlet filter screen is plugged or the valve is toast.
If no voltage check that the float (overflow) switch is closed.
Check that the wires from the timer to the valve have continuity.
Check that both door switches are OK.
Whirlpool Gold Dishwasher not running cycles properly (Dishwasher Repair)
by Joe513 6/20/2022 12:49:46 PM(UTC)
GE Top load HE washer not running any cycles (Washer Repair)
by jonesfam0601 12/12/2018 5:39:46 AM(UTC)
Whirlpool Washer not running (Washer Repair)
by junooni 12/23/2013 2:24:53 PM(UTC)
Kitchenaid Dishwasher Not Running KUDS25SHWH0 (Dishwasher Repair)
by Appliance_Matt 10/10/2013 10:07:16 PM(UTC)
Ge washer not running with burning smell (Dishwasher Repair)
by larrykelley55 5/2/2012 10:56:57 AM(UTC)
Dishwasher not running (Dishwasher Repair)
by Skinnyrich 4/8/2012 7:58:31 PM(UTC)
Dishwasher not running through cycle, but turns on. (Dishwasher Repair)
by nunyaabidniss 2/18/2012 4:07:33 PM(UTC)
washer not running (Washer Repair)
by ajm1979 9/3/2011 4:20:36 PM(UTC)
Kitchenaid Dishwasher not running (Dishwasher Repair)
by Lt0012 6/4/2011 12:41:57 PM(UTC)
Maytag A7300 Washer not running (Washer Repair)
by electrifier 11/11/2009 3:16:28 PM(UTC)
by JMJNet 10/31/2009 6:02:52 AM(UTC)
washer not running through cycle (Washer Repair)
by fvento 10/19/2009 5:42:07 PM(UTC)
Bosch Dishwasher Not Running (Dishwasher Repair)
by Shiloh376 4/10/2009 2:27:42 PM(UTC)
