gclosius
#1 Posted : Friday, November 27, 2009 2:58:48 PM(UTC)
gclosius
My Maytag front load washer will only fill with hot water. What should I look for?
sidfink43
#2 Posted : Sunday, November 29, 2009 11:27:34 AM(UTC)
sidfink43
I am sure you have checked the cold water supply, so next check where it is connected to the inlet to make sure the inlet screens are not clogged.
If they are free, take off the valve and see if you have 120v coming to the cold water valve when it is supposed to be open. If so, then replace the valve assembly.
Here is the service manual which will show you how to access the valves.
http://www.servicematters.com/m...ibrary/docs/16010061.pdf
