Dean Family
#1 Posted : Friday, November 27, 2009 2:27:04 PM(UTC)
Dean Family
It seems our touch pad became loose and food entered it. It now shows ERR Stuck Key. We tore it apart and cleaned everything but it remains the same. What will be needed to repair? It looks like the part # is 9756595BL for the switch membrane. Do you think this is all that will be needed to repair? Is it difficult to do? Where is the best place to buy the part? Any help is appreciated. Thanks!
#2 Posted : Saturday, November 28, 2009 6:27:07 AM(UTC)
Replacement parts for WHIRLPOOL KESA907PBL00 30" Slide - in Electric Oven Convection | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%209761075.pdf
Try the below cleaning if there is any possibility that it may still be dirty though by the sound of it this will be a long shot.
Probably needs a new keypad. Unfortunately they do not give a pin-out for the keypad so you cannot really check it.
Try disconnecting the keypad from the control board. If the error switches to a keypad disconnected then I would replace the keypad. Still a bit of a crap shoot but your odds are better.
As I said it is a bit of a crap shoot all you can do is narrow the odds.
You have already pulled it apart once so you were 90% there
You could try AppliancePartPros.
I have see a number of compliments about them on this forum.
Also they host/ pay for this forum where most companies do diddly.
