My dryer doesn't heat, the information on the door suggest checking the 2 fuses in the main switch box. I have taken off all the panels and still can not find the main switch box? HELP were is it?
Originally Posted by: radio963  My dryer doesn't heat, the information on the door suggest checking the 2 fuses in the main switch box. I have taken off all the panels and still can not find the main switch box? HELP were is it? DRYER NOT HEATING AT ALL. I HAVE REP;ACED THE THERMAL FUSE, THERMAL CUTOFF AND THERMOSTAT TO NO AVAIL. CHECKED HEATING ELEMENT READING 8.2 OHMS. VOLTAGE TO DRYER AT 228VAC. HELP.
