rungsat69
#1 Posted : Tuesday, November 24, 2009 7:55:45 AM(UTC)
rungsat69
I have a frigidaire FRS22WNC side by side fridge. the freezer is cold the fridge temp right now is 56 degrees. A technician just replaced the thermostat and he defrosted a large hunk of ice in the freezer. This has not corrected the problem. What could be the other problems with the frigde.
thanks
rung
#2 Posted : Wednesday, November 25, 2009 4:23:49 AM(UTC)
Replacement parts for FRS22WNC models | AppliancePartsPros.com
How long have you left it, it needs at least 12 hours.
This concerns me as it indicates that you may have a defrost problem. Note that it usually take 4 or 5 days to show up as a problem after a unit has been manually defrosted.
Make sure the evaporator fan is running.
Check that the damper Item 115 in Section 3 is open and cold air is entering the fresh food section.
