rebsimoneaux
#1 Posted : Tuesday, November 24, 2009 6:50:57 AM(UTC)
rebsimoneaux
Main problem is washer won't spin sometimes...
To start, my washer overflowed when draining (to floor and sink), we cleared the vent pipe and when it does drain, there is no overflow. i moved the washer to clean up. The washer worked fine before the overflow.
Now, i get a handful of different results.
Medium Load, Reg Cycle, Heavy Wash with Clothes: Filled, Agitated, Dial clicks and turns to Rinse without Spinning or draining, Agitates, then clicks to Finished position.
One time it agitated until “normal” and then stopped and dial turned to finished. Most recently it agitated the full time and then the dial just turned to finished position.
Medium, reg, Heavy, no clothes: Filled, agitated, spin and drain ok, fills to rinse, no agitation, no spin or drain.
Normal or Light wash, clothes or no clothes: fills then dial makes its way to finished position.
Gentle cycle, med,normal: agitates, no spin or drain, agitates, then spins and drains ok.
When it isn't spinning, only sound i hear is click of dial and a rhythmic heartbeat sound when i put my ear to the lid.
i can put dial at end of gentle cycle to spin and drain...
Suggestions??
sidfink43
#2 Posted : Friday, November 27, 2009 8:51:10 AM(UTC)
sidfink43
Since it will work on a mechanical basis at some times I am going to suggest you replace the timer. You should call in the order with both your model and serial numbers to be sure you get the right one.
