LIFAS
#1 Posted : Monday, November 23, 2009 3:05:27 PM(UTC)
LIFAS
I just bought and installed this Frigidaire SS fridge today. It's been plugged in for 12 hours or so and it doesn't seem to be cooling. It is running and it's cooler than the kitchen, but it's 44 degrees F in the freezer and 48 degrees F in the fridge.
When I originally plugged it in, it beeped an error message saying "High Temp".
I have it set to 0 in the freezer and 35 in the fridge.
Please let me know I just have to adjust something.
Matt
#2 Posted : Tuesday, November 24, 2009 4:31:45 AM(UTC)
Try setting the freezer temp to 5 degees F.
LIFAS
#3 Posted : Tuesday, November 24, 2009 4:41:36 AM(UTC)
LIFAS
Denman,
Thanks for the suggestion. I have set it to 5 degrees. If in 5 hours it's still above 30 degrees, what do you suggest?
I truly appreciate your help.
Matt
#4 Posted : Tuesday, November 24, 2009 7:06:40 AM(UTC)
Get it fixed under warranty.
If you start messing with it you may give them a reason to void the warranty on you.
LIFAS
#5 Posted : Tuesday, November 24, 2009 7:53:04 AM(UTC)
LIFAS
Oooh...I bought these second hand, but unused, but Frigidaire said they are under warranty until next year. That makes this problem much easier to solve.
I wasn't even thinking about calling them until now! Thanks!
Matt
