bobinx
#1 Posted : Monday, November 23, 2009 8:53:14 AM(UTC)
bobinx
My Dryer wont start :(
Diagnostic test gives an F26.
The element is visibly broken & needs to be replaced. What else should I look at/replace before I order this element?
#2 Posted : Monday, November 23, 2009 4:26:05 PM(UTC)
Replacement parts for WHIRLPOOL WED8300SW0 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208572759.pdf
Unplug the unit for 20 minutes or so.
Then give it a try to see if the error still comes up.
If it runs OK but just does not have heat I would just order the heater.
If the error still occurs. Run the diagnostics as shown in the tech sheet.
