AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Amana SGD22TW refrigerator cools properly for a while then stops cooling.
My Amana side by side started defrosting all the way in the freezer. Ice, etc. would melt. Then in a couple of days it would start freezing/cooling properly. Then it didn't cool at all. I left it off for a few days plugged it in and ran it for a while. After 45 minutes the freezer got down to 25*, half hour later, back up to 45*.
I took the back off of the freezer compartment exposing the evaporator and fan section. The fan was working and the coils where frosting up for the little while it worked.
The compressor fan in the back of the unit is also working ok. Could this be a defrost thermostat problem? The only way to ohm that out properly is for it to be below the closing temperature, right? So, if I can put the thermostat in another freezer and leave it there for a little bit I shuld be able to ohm it out.
I would be grateful for any help. Semper Fi.
THIS FORUM IS DEAD!!!!!!! |
