Need Motor Replaced But Can Not Get Fan Off Of Motor To Remove. Have Taken Clap Off But How Do You Remove The Fan Of The Shaft To Slide It Throught The Body Of The Dryer?
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman Denman's advise is correct, but usually by the time the motor goes out the blower is on for good. So I would buy a new blower, and then take the back off the dryer, and where the filter goes in, there are four screws that hold the blower housing in place, they are 5/16th of an inch screw, and remove the housing. Then , the way I do it is get a hammer and pound the center out of the blower wheel, and then remove it. The $15.00 for the new blower wheel is worth the aggravation, and, you will only teat up the blower shaft. Tom www.applianceweducator.com
