hundoracer
#1 Posted : Friday, November 20, 2009 8:10:27 PM(UTC)
hundoracer
Forum Rank:: Member
Okay. 2nd post. Hopefully, I will get some responses here.
In ordering a new outer glass for our range, part # 3196810 is the only glass door that is available. However, it is one solid piece of white opaque glass. The original glass door had a "window", which paired with inner glass could still see inside the oven.
The part looks more like the door glass on RF212PXSQ. I took pictures of the glass, the window in the range and an example of what the glass should look like.
UserPostedImage
Below is the window into the oven. Should have a piece of glass over this, with a "window" like the above picture.
UserPostedImage
Below is the picture of the solid glass piece. NOT CORRECT!
UserPostedImage
hundoracer
#2 Posted : Friday, November 20, 2009 8:12:27 PM(UTC)
hundoracer
Forum Rank:: Member
pictures didn't work. will try again.
UserPostedImage
hundoracer
#3 Posted : Friday, November 20, 2009 8:20:11 PM(UTC)
hundoracer
Forum Rank:: Member
duplicate post
