Our fridge came with the house we just bought. Today it stopped cooling. Both the fridge and the freezer are getting warm. HELP!:confused:
Remove the back cover and check if the compressor and the condenser fan (next to the compressor) are running. If they both are not running, locate the defrost timer (#22 on the unit break down diagram) and using a flat screwdriver, slowly turn the shaft CW for about 90°. See if the compressor will start. Post your findings. Here are the break down diagrams for the Maytag refrigerator Model LRTD19AGene.
