paton
#1 Posted : Thursday, November 19, 2009 9:50:57 AM(UTC)
paton
How do I disassemble the door in order to replace the broken handle as well as the latch spring. Then, how do I replace them?
applianceman
#2 Posted : Tuesday, November 24, 2009 8:20:10 AM(UTC)
applianceman
This page will help with replacing the door handle. GE Spacesaver Microwave Handle Replacement
Once you get to the point that you remove the inner door trim you should see the spring. That latch just lifts up off two pins. Once off replacing the spring will be easy. However at times I see the hole that the spring hooks into break out. To repair this I drill a small hold for the spring to hook onto. Hope this helps!
paton
#3 Posted : Tuesday, November 24, 2009 12:08:28 PM(UTC)
paton
THANK YOU SO MUCH! I will try this and know I will have success. You are kind to take the time to answer my query.
