Problem: No water from door fill up or ice maker What I know. - Can manually fill ice maker with water and makes 1 tray of ice - Replaced Water Valve Part Number WR57X10026 - Input water flows fine into a bucket - No water goes to ice maker or door fill up - Disconnected electrical connectors going to orange output tube and measured 127.4 v on the red connector in and 15.6 v on the blue connector in - Disconnected electrical connectors going to brn/blk and white tubes and measured 115v on red input and 15.4 v on blue input - Put brn/blk tube coming from filter into a bucket after connecting all wires and no water comes out when refrigerator plugged in.
Where does the blue connector electrical inputs come from. Shouldn't this input be 115v to pull the solenoid. Is there a bad board here? Which board?
It looks like water comes in, solenoid engages, output thru the orange tube up to the filter and back down into the brn/blk input and out again to the white 1/4 " to the ice maker and the 5/16" tube to the water fill.
Clark
Replacing the water valve seems to have solved the problem. Thanks
