donnakay31
#1 Posted : 18 years ago
donnakay31
Hello,
We discovered that the washer has a slow not gushing leak. The water is appearing on the left side of the washer on the floor. We opened the washer and didn't see anything that seemed to be causing the problem.
The waterpump seems dry although about 6 inches away toward the back of the machine, the metal flooring brackets on the bottom was collecting water. We also watched the machine during different stages and still couldn't determine what could be causing this problem.
Any help would be greatly appreciated.
Thank you,
Donna
donnakay31
#2 Posted : 18 years ago
donnakay31
The discharge hose had a hole it. The vibrations caused by the washer during spin cycle caused it to rub the hole.
Thanks to everyone who read this thread.
Donna
#3 Posted : 18 years ago
Good job donnakay31!
Kenmore washer mystery leak (Washer Repair)
by 1967hammer 15 years ago
Mystery Leak? (Washer Repair)
by Prof. Maneuver 16 years ago
Mystery Leak 2 (Washer Repair)
by LLcoolLutz 18 years ago
