Hi Folks, Just a question regarding my Kitchenaid Dishwasher. I'm a novice, so please bear with me. My Dishwasher stopped working (All Power). I isolated the problem to the Thermal Fuse being defective or malfunctioning. I've ordered another Fuse and am not attempting to re-connect he wiring harness to the Control Panel. I don't have my Schematic with this Dishwasher and was unclear which wires go where. Some of the connections are obvious, in other words they only fit a certain way, but there's several wires that I'm not sure which connections they fit on. I don't want to plug the wrong wire to the wrong terminal. Just want to be safe. In other words, there's a single black wire with a white stripe and a single black wire. Which wire goes on which terminal. Also two sets of wires that plug into two seperate inputs. Or does it matter. I've tried ordering or locating a Wiring Schematic for this Dishwasher, but I can't locate one online or through Kitchen Aid. Any suggestions? Thanks a million for your help. Part Details - WHIRLPOOL Electronic control assembly, part number: 8564542
