I've been told I need a gas valve for this. The serial/model plate is flattened and unreadable. Anybody know where I can get one of these? The year is approx. - I have a '78 mobile home and it was in the home when I got it, so I assume it's around 1978 model. It does say Elegante on the oven.
I have the same model wall unit in a 1981 moble home,i'm looking for the valve that goes to the burner not sure what they call it,any help thanks,model #r92ka-3w ser#16824m9
Thanks for the model number, at least. I didn't even have that much. It might help me locate someone for both of us.
Later. Evie
does anyone know where to get the parts to this range. It is from late `1970's. I am hoping to find the oven door seals and the switch to the fan that is at the top of the unit. The model # wore out and the serial # I uploaded and image of the range I found on the internet yesterday. thanks... dannala attached the following image(s):
How do you get parts? Electric both broiler and oven elements went out at once?
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a Elegante wall oven. How do I find parts?
