the dryer works fine except it won't shut off. it will run through it's cycle and the buzzer will continue to ring.there is always power you don't have to hit the start button .i unhooked it does'nt make a difference.also motor now won't start without a push but runs fine then.:confused:
Most likely the problem with your dryer is a bad timer.
Unfortunately the timer is no longer available.
