Hello! How am I suppose to put the belt on the pulley and motor pulley if the drum is over the Item, and at the same time get the belt over the drum this is really not easy. Help me please:confused:
Hi Marion
Hope you saw the earlier reply on how it goes. To get the belt on you put in the drum, then loop the belt over it. Now you have to reach in under the drum and push down on the idler pulley to get the belt to loop over it and onto the pulley on the motor.
You are correct, this is not easy and I have the scars to prove that. Just be careful, and if you can find someone with small hands who is willing to risk it, get them to do it.
Good luck.
