AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
mAYTAG GAS DRYER DRUM GLIDE BRACKET REPLACEMENT
I would appreciate installation instructions or tips for replacement of the drum glide brackets. Thank you
Hi Steve, As I can see from the break down diagram, the drum glide bracket (#13) is mounted with two screws. Why do you think this part has to be replaced? Gene.
Dryer Repair
