ktcox67
#1 Posted : Saturday, November 14, 2009 6:32:57 PM(UTC)
ktcox67
Hello All,
I have a DCS dual fuel oven that has the grill top installed. It was working great until I slid the cleaning tray out and shorted the ceramic igniter wires. This caused the gas valve to short and break. Yesterday I replaced the gas valve and tested the grill operation. Everything worked great until I went to put the stove back together. It doesn't work any longer and I am stumped as to what it could be. This is a 3 volt A/C circuit but I never can measure 3 volts. I have tested the circuit using an ohm meter by eliminating the componets. The gas valve, wires, and switch measure ok. The cermic lighter measures about 178 ohms resistance.
Any thoughts or advice is greatley appreciated.
