Several months ago the ice dispenser in my side by side stopped working, it makes a humming noise but the screw will not turn to either dispense or crush ice (even after taking the ice out of the bin & no other obstructions). Ice maker makes ice just fine.
In addition the water dispenser hesitates and usually dims the dispenser area light when it turns on and then after water flows for a few seconds the light returns to full power. There are no known problems temperature wise with either the freezer or the refrigerator side. Everything else seems to work normally.
Any ideas?
I would try replacing main control board
