The oven keeps beeping with a F1 fault code on display. Temporarily stops when "STOP/CLEAR" is pressed. But starts again in a few minutes/seconds. I finally had to turn off the circuit breaker. When I restart, it could be several hours before it starts beeping again. Once it starts beeping, the only way to stop it is to switch off the oven circuit breaker.:confused:
Here are your parts Replacement parts for MAGIC CHEF 59G-5TXW | AppliancePartsPros.com F1 1. Watchdog on board 2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board
Above is the only info I could find on erro codes on a Magic Chef. |
THIS FORUM IS DEAD!!!!!!! |
