FDAR
#1 Posted : Friday, November 13, 2009 2:16:43 PM(UTC)
FDAR
I am working on a maytag dryer, when you push the start button there is a buzzing noise. I tried bypassing the fuses 1 at a time and then tried all of the thermostats 1 at a time and continued to hear the buzzing noise. I then found the buzzer located on a panel in front of the motor. I bypassed the buzzer and the dryer worked perfectly every time I tried it, so I ordered a new buzzer thinking this was the problem. Installed the new buzzer and now have the same problem, buzzes everytime I push the button. The drum spins freely and blower wheel is clean. Has anyone had this problem? Any help greatly appreciated. Thank you.
Mike
Qtip
#2 Posted : Friday, November 13, 2009 7:21:02 PM(UTC)
Qtip
Have you tried opening the dryer door and holding down the door switch and the start button while a 2nd person manually spins the dryer drum? (all has to be done simultaniously) if dryer starts after doing that then most likely bad motor.
#3 Posted : Saturday, November 14, 2009 12:41:29 AM(UTC)
Probably a bad switch mounted to the motor. Take the cover off and clean the switch contacts, or order a new one if available.
