ablatt
#1 Posted : Friday, November 13, 2009 10:31:39 AM(UTC)
ablatt
I just got a 48" KitchenAid, model KSSC48FTS03 a month ago.
I have the freezer set to 0 and the fridge to 37.
Periodically (every day or two that I notice) the freezer will go to -9 on it's own (I don't have deep cool on) and stay there for a couple of hours and then return to 0.
When defrosting, the temperature on either side never goes above 0 and 37 on the display.
In fact, I can open the doors for a few minutes, and even though the real temperature has gone up on both sides, the temperatures on the panel still show 0 and 37.
Is this normal behaviour? Is it a firmware, thermistor or temp. control board issue?
By the way, Whirlpool Canada has 3 service company options for repair/support of this fridge and I've already had two of them here and neither had any clue about the temperatures. Maybe I should try the third.
#2 Posted : Saturday, November 14, 2009 2:58:07 AM(UTC)
Could not find a current manual but here is a 2003 manual
https://secured.whirlpoo...6cf458/$FILE/4317344.pdf
It could have something to do with Max Ice, see Page 3-5. They may have changed the -5 degrees to -9 degrees on the newer models.
