et_lambert
#1 Posted : Monday, February 25, 2008 9:37:03 AM(UTC)
et_lambert
Bosch needs new circulation pump(works fine just very noisy when running) Told need pump AP2826384 .When installing ,will I need to have other parts such as gaskets or anything on hand.I don't want to get it out then find I need something else.Your help is greatly appreciatted.
Thank you
Phil
Servicer
#2 Posted : Friday, February 29, 2008 8:37:11 AM(UTC)
Servicer
There's a one-time use clamp that is used on the seal that goes between the pump housing and the heater which you should also have on hand. The Bosch number is 172272.
Bench test bosch circulation pump? (Dishwasher Repair)
by Jlagraff 4/16/2013 9:18:11 PM(UTC)
Cannot remove Bosch circulation pump! (Dishwasher Repair)
by tony2222 1/20/2013 10:29:53 AM(UTC)
Replacing a Bosch Circulation Pump for Dishwasher (Dishwasher Repair)
by sabphi 12/25/2009 11:33:49 AM(UTC)
Bosch Circulation pump, low flow but nothing visably wrong. (Dishwasher Repair)
by Terry O'Brien 6/7/2009 2:08:05 PM(UTC)
